After upgrading to Desktop 10.5 the FME workbench I use to move feature classes from Postgres to Oracle fails during shutdown. The Windows Appcrash points to BGLAPILib.dll as the fault module. The module appears to be part of the Esri 64 byte background processing package which apparently was changed going to 10.5.
The feature classes are being read and written correctly but it fails during the shutdown. I have unloaded and reloaded the software packages and rebuilding the workbench. Has anyone else had this problem and is there a work around or a hot fix?
Any help would be appreciated.
Just curious - were you ever able to get an answer to this? I am having the same issue
