Authorization Error
3576
8
07-05-2017 07:42 AM
KRISHNA_CHAITANYATATA
I have ArGIS Destop 10.2 licenses, and i need to install on server. But server is ot having internet, so in order to generate ecp file, i generated authorization.txt in other machine and uploaded to https://service.esri.com/drm and given me a ecp file but when i copied this to server and tried to authorize licenses. It is giving an error "There were no valid features selected in file."
Tags (1)
JayantaPoddar
ECP file is for authorizing ArcGIS Server, not ArcGIS Desktop.
Do you have license codes for ArcGIS Desktop?
Moreover the error message suggests that you have used/activated all the licenses.
Think Location
Hi yes i have codes. And i generated ecp file.
So you are saying that, licenses are activated on other machine?
JayantaPoddar
Do you have Single Use (SU) License or Concurrent Use (CU) License? If SU, then authorization has to be done using ArcGIS Administrator. If CU, then authorization has to be done using License Server Administrator (License Manager).
See Authorizing your software—Help | ArcGIS for Desktop
Think Location
I have CU licenses.
How can i activate them on server, not that server is not having internet
Thank you Jayanth. I got it.
