10.4.1 Hangs and Never Opens
3859
07-28-2016 12:58 PM
CarlosMartinez2
I'm having a problem installing/running 10.4.1 when after the installation of 10.4.1, the application fails to launch.  The opening sequence starts and reaches "Loading Document" and then mysteriously vanishes.  I had this same problem when I installed 10.4 on the same machine and our IT group said it had something to do with Python 2.7.11 which was installed on my machine for a Python course (which was confirmed by our PS rep). Once that version of Python was removed, ArcMap opened with no issues.  The only version of Python on my machine currently is the version pre-packaged with 10.4.1 which is 2.7.10. Typically I'd just call PS, but since we block any screen sharing outside of our company it's a bit difficult.  Anyone experiencing anything similar?
CarlosMartinez2
ArcMap 10.1 hangs on Loading Document
The answer resides in there.  It has to do with the installation of Python 2.7.11.  It's looking for a registry that doesn't exist and causes it to not complete the loading process.  Updating to 2.7.12 remedies this process immediately and doesn't even require a reboot.  #solved
DanPatterson_Retired
Can you get someone else to login to your machine and see if arcmap works for them.  If it works for someone else, you have eliminated one potential source
CarlosMartinez2
Dan,
Yes, we have tried that with no success.
One down...
Now, did you deviate from the instructions here? Introduction to installing and configuring ArcGIS for Desktop—Help | ArcGIS for Desktop
Did you install anything after you got 10.4 to work?
CarlosMartinez2
Nope.  Standard install.  I've tried doing a custom install removing Python as well as completing removing all traces of ArcGIS installs from my machine (including past work).  What really makes this challenging is the fact that it doesn't ever drop an error.  It just stops trying to run yet the only thing that actually continues to run is the ArcGIS Cache Manager.
CarlosMartinez2
