Does anyone know the difference between TDS and TDS ICM.gdb?
1560
02-16-2018 03:50 AM
IroArgyrou
Does anyone know the difference between TDS schema and TDS ICM.gdb in the defence mapping? I want to use a defence schema for 25k and 50k maps and i want to know the difference between these two databases. As i know ICM is a city map schema and TDS a Topographic Data Store (Global) 1:1000000.
So what about TDS_ICM?
Bo_King
Esri Alum
Hi Iro
The TDS_ICM schema is a subset of the TDS schema that can be used to build ICMs using the ICM_TDS map templates.
Regards,
Bo
IroArgyrou
Hi Bo,
thank you for your answer. It is clear now...
Regards
Iro
