How to do Multiple Regular Expression Checks in a Single Field
4514
08-27-2013 05:28 PM
TedCronin
Is it possible to use an Or inside of a Regular Expression Check somehow, for example as TR 12345 or TR 1234, something to the effect of [A-Z][A-Z] [0-9][0-9][0-9][0-9][0-9] OR [A-Z][A-Z] [0-9][0-9][0-9][0-9].
I know the above does not work, but what is the recommended approach for doing Multiple Regular Expression Checks in a Single Field.
Another Occurrence would be TR 12345 OR TR 12345-1, because conceptually I can solve this (TR 12345 or TR 1234) as
[A-Z][A-Z] [0-9]+
MichelleJohnson
Use | as the OR.  For example,
TR 12345-1 OR TR 12345 OR TR 1234
([A-Z][A-Z] [0-9][0-9][0-9][0-9][0-9]\-[0-9])|([A-Z][A-Z] [0-9][0-9][0-9][0-9][0-9])|([A-Z][A-Z] [0-9][0-9][0-9][0-9])
MB 000/000 SD OR MB 000/000
([A-Z][A-Z] [0-9][0-9][0-9]\/[0-9][0-9][0-9] [A-Z][A-Z])|([A-Z][A-Z] [0-9][0-9][0-9]\/[0-9][0-9][0-9])
Cheers,
michellej.
GISDev1
In you use-case examples, multiple expressions don't seem to be necessary.
What's wrong with the "+" solution you posted?
TedCronin
Absolutely, that does work, but what I really need is where I have a Tract with a number and a Tract with a -1 at the end.  Really bad example on my part I suppose, since I already use the [A-Z][A-Z] [0-9]+ where I can do exactly what I asked such as grabbing a 4 + digits.
Other examples where I need an OR MB 000/000 OR MB 000/000 SD...
TedCronin
It would be nice to add to the Composite Check the ability to add a SQL Check and then combine the SQL Check with a Regular Expression Check, or even a couple of Regular Expressions Checks where, I can Extract out what I am referring here in an OR via SQL, then be able to stack multiple Reg Expressions, essentially.
MichelleJohnson
Cheers,
michellej.
TedCronin
Sweeet.
Cheers Indeed.
I was not seeing the expected results with just using Spaces, but explicitly insert white Space seems to do the trick.
([A-Z][A-Z]\b[0-9][0-9][0-9][0-9][0-9]\-[0-9])|([A-Z][A-Z]\b[0-9][0-9][0-9][0-9][0-9])|([A-Z][A-Z]\b[0-9][0-9][0-9][0-9])
Seems like the | can get inserted into the Help for OR, what is the symbol for AND.  Currently | is Matches an alternative phrase or spelling, in the help.
I also like how you use () and use \ for even /...
