Gap Sliver
5900
6
03-08-2011 06:45 AM
DevinUnderwood
An error which is displayed on the jpeg. However there is no problem, can anyone explain why an error is flagged?
KumarBhardwaj
Thanks for providing the screenshot. However, It is hard to tell from the screenshot if it is a legitimate error or not. The red area indicates an error.
Please confirm the following:
1. Did you install Esri Production Mapping 10 or ArcGIS Data Reviewer 10?
2. What is the build number for Esri Production Mapping 10 or ArcGIS Data Reviewer 10?
3. Can you send a screenshot of your Polygon Sliver Check Properties dialog?
4. Can you attach the data?
TedCronin
I am stepping in here, briefly, but will refer back to Devin for the issue, and his response.
Data Reviewer 10 SP1.  How do we find the build number, if only Reviewer is installed?  Screenshot to follow, and data is there, already.
DevinUnderwood
Thanks for the response
KumarBhardwaj
Thanks for bringing up this issue to our attention, following bug has been logged for this issue:
Bug ID : 8260
Title    : Invalid result with Polygon Overlap/Gap is Sliver Check
AshleyMott
Does this bug still exist in sp3?
KumarBhardwaj
Hi Ashley,
Bug 8260 has been resolved in SP3 for ArcGIS Data Reviewer 10.
