Transitioning from .rbj to reviewer rules. Rule is failing to calculate area size correctly and marking all features as under size.
Same data and process using .rbj rule works perfectly.
Using ArcGIS Pro 3.1
Thanks in advance
Danny from Down Under
Can you share some additional details on the workflow/environment that you configured your Evaluate Polygon Perimeter and Area check?
This would be helpful in troubleshooting
Thanks!
Hello Danny, I'm noticing that the configuration in the image had a Subtype picked, I wanted to confirm this is the case as this was scratched from the snapshot. Thank you.
