Evaluate polygon, perimeter and Area Validation rule - Not calculating area correctly
1488
03-18-2024 05:35 PM
DanielMcculloch
Transitioning from .rbj to reviewer rules. Rule is failing to calculate area size correctly and marking all features as under size.
Same data and process using .rbj rule works perfectly.
Using ArcGIS Pro 3.1
Thanks in advance
Danny from Down Under
JayCary
Can you share some additional details on the workflow/environment that you configured your Evaluate Polygon Perimeter and Area check?
  • Was the validation attribute rule created manually from the Ready to Use Rules gallery or exported/imported from a Reviewer Batch Job file.
  • The geodatabase type and the spatial reference of input dataset
This would be helpful in troubleshooting
Thanks!
FranciscoPerezGiusti
Hello Danny, I'm noticing that the configuration in the image had a Subtype picked, I wanted to confirm this is the case as this was scratched from the snapshot. Thank you.
