Domain Check Error Message
7701
15
03-23-2011 04:51 AM
JessicaGould
I am getting the attached error message when running a Domain Check on my data.  I have tried it on several different feature classes and am consistently getting the error on all feature classes in my geodatabase.  Any ideas on what it means?  Thanks!
Domain Check:  Unable to narrow selection
DanHopkins
Jessica,
Do you work in the Greater Philadelphia Area? How can I get a hold of you outside this forum?
-Dan
JessicaGould
Yep, I work for the City of Philadelphia.
I ran the subtype check on my feature classes and it appears that all subtypes are valid.
again, thanks for your help!
DanHopkins
Jessica,
To let other users know, we have communicated outside this forum. You have provided Esri with some data to reproduce the issue. You have identified the cause of the issue. I have reproduced the issue and I have logged the following NIM on your behalf:
NIM066631 - Get error Unable to narrow selection when running Domain Check
You are encountering the following Reviewer Processing Error: 'Domain Check: Unable to narrow selection (wMainLine)' because the Domain Check is having issues with Date Range Domains. If you remove the Date Range Domain from the field and delete the Data Range Domain from the database, you are able to run the Domain Check without error. You are encountering this error at PLTS 9.3.1 GIS Data ReViewer and ArcGIS Data Reviewer 10.
I have spoken to the ArcGIS Data Reviewer Product Manager. The Product Manager states they are going to try and get this fixed for Patch2 for PLTS 9.3.1 Foundation SP2. I do not have an ETA on Patch2 at this time.
Regards,
Dan
MichelleJohnson
Patch 2 for PLTS 9.3.1 Service Pack 2 has been released that addresses this issue. The patch can be found here.
JessicaGould
We recently tried to run the Domain check - we are now at 10.1 - and we are still getting the same error message.  Is this still a bug at 10.1?
Thanks!
DanHopkins
I am running ArcGIS 10.1 Data Reviewer for Desktop SP1 Patch4 Build 1751. Using the data you provided to me back in 2011, I do not encounter NIM066631 - Get error Unable to narrow selection when running Domain Check.
What service pack and patch are you running for ArcGIS 10.1 Data Reviewer for Desktop?
