Table to Table attribute check
2682
04-02-2013 01:22 PM
satyaanveshnadipalli
Hello every one iam getting an error when running the table to table attribute check. actually iam trying to check the ownership between site record and owner record. the error was "cannot run check:at least one data sourse is not present" but I have given both the data sources plz help me
thank you,
regeards,
anvesh.
KumarBhardwaj
Hi Anvesh,
Please let me know how you are running this check, i.e. as an individual check from ArcMap or from a batch job:
- If you are running this check from a batch job
> please open a new ArcMap document
> Open Reviewer batch job manager
> Add your batch job and click Validate.
> Click OK to add the layers in your map and make sure that both layers are added properly.
> Make sure that you have no validation errors.
- If you are running as as individual check:
> Please make sure that layers are present in the map and no layer has broken resource.
Kumar
Hello kumar,
           thank you the problem is solved yesturday as the way you said by usind batch job.
thank you,
anvesh.
