Domain Check Error Message
7696
15
03-23-2011 04:51 AM
JessicaGould
I am getting the attached error message when running a Domain Check on my data.  I have tried it on several different feature classes and am consistently getting the error on all feature classes in my geodatabase.  Any ideas on what it means?  Thanks!
Domain Check:  Unable to narrow selection
DanHopkins
1. Which version of Data Reviewer are you using?
2. What is the build number for Data Reviewer?
JessicaGould
Feature : Reviewer
    Build Number : 175
    Product Version : 93.01.00.00
    Install Date\Time : 3/11/2011
DanHopkins
Thank you for your response.
You are running PLTS 9.3.1 GIS Data ReViewer Release build 175 that was released in April 2009. As of today, the latest release for PLTS 9.3.1 GIS Data ReViewer is SP2 Patch1 Build 775.
Please do the following:
1. Install SP2 Build 629 for PLTS 9.3.1 Foundation from the link below:
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=34&MetaID=1650
2. Install Patch1 Build 775 for PLTS 9.3.1 Foundation SP2 from the link below:
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=34&MetaID=1736
After you install the latest release, what happens?
JessicaGould
Thanks!  I installed the SP and patch and still receive the error message, now with the additional information of the feature class name in parenthesis.  See attached .png
DanHopkins
Thank you for the screenshot.
Do you have any domains with no values?
JessicaGould
I looked thru all of the coded value domains in my geodatabase and it looks like they all have values associated with them.
DanHopkins
Can you attach or send the data?
JessicaGould
I really appreciate your help.  Do you happen to have a FTP site that I could post the data to?  I was trying to only export a small spatial extent of the data in order to send you a smaller .zip file, however when I rerun the check on that subset of the data, I no longer get the error.
My file size is 29 mb.
Thanks!!!
MichelleJohnson
Do you have any invalid subtypes on your features?  That would cause the domain check not run on those features.
