ArcGIS Pro 3.0.1: The “duplicate vertex” attribute rule fails to be saved,
1258
09-09-2022 04:21 AM
JamalNUMAN
Legendary Contributor
As per the screenshot, the “duplicate vertex” attribute rule fails to be saved
What could be the issue here?
Jamal Numan
FranciscoPerezGiusti
Hi Jamal,
This is likely because the editor tracking and global ID fields are not enabled on the feature class, you might want to confirm this boxes are checked by right-clicking on the feature class to enable the context menu and select the Manage option:
Example
Francisco Perez
Hi Jamal,
Example
Francisco Perez
JamalNUMAN
Thank you Francisco. It works fine
Jamal Numan
