Hi Everyone,
I have a CSV file of microwave paths. Each record has two sets of X, Y and Z to make a line. Z comes in either feet or meters. X and Y are WGS84 - which i defined in the CSV Reader.
So far, I think I have figured out how to make just the 2D lines. Use two VertexCreator transformers together, first one configured with the "From" X, Y - and the second with the "To" X, Y. I use the Add Point Mode to step from the first VertexCreator making the original point and then ADDING the next POINT to make a line with the second VertexCreator.
In both of those VertexCreators, would I have to do a conversion of either Meters or Feet to Degrees for the Z value since I have defined WGS84 in the reader?
--Adam
