Use a user selected feature layer in an ETL tool
1352
05-09-2025 02:40 AM
MattHowe
I'd like to create a DI workspace where the user can select a layer in the current map, then take that layer in the workspace and run some ETL processes on it. Is it possible to create a user parameter that would allow this?
It could be a feature class, or shapefile and so is dynamic.
BruceHarold
Esri Frequent Contributor
Hi Matt, yes this can be done.  Create a layer file then use the Esri ArcGIS Layer reader, set to point at the LYR or LYRX file.  Definition queries are honored, it's a really great workflow.
BruceHarold
MattHowe
Fantastic, thanks very much @BruceHarold !
RenatoSalvaleon3
@MattHowe is you want to take it up a notch and see the results of your ETL tool, you can read on Bruce blog on how to add results on the current map.
https://community.esri.com/t5/arcgis-data-interoperability-blog/quick-import-to-memory/ba-p/1589757
