Quick Import (Data Interoperability) GP tool failed after publishing on server (10.81) as web tool
2141
05-06-2024 04:49 AM
Hari
Developed a python  script to convert a KML file to feature class using arcpy.interop.QuickImport().
Script is working as expected while executing in ArcGIS Pro and Jupyter notebook but failing  after publishing on server (10.81) as a web tool with the following error message.
Please help me to identify and suggest any solutions.. Thanks in advance
Error Message:
Submitted.
Executing...
Start Time: maanantai 6. toukokuuta 2024 12.04.16
D:\arcgisserver\directories\arcgisjobs\qitest_gpserver\j8f5cd54b4eb34e0a8a556eb1653c6d9f\scratch\Klippan.kml
D:\arcgisserver\directories\arcgisjobs\qitest_gpserver\j8f5cd54b4eb34e0a8a556eb1653c6d9f\scratch\scratch.gdb
Failed script QiTest...
  File "D:\arcgisserver\directories\arcgissystem\arcgisinput\QiTest.GPServer\extracted\cd\glint\qi_test.tbx#QiTest_qitest.py", line 16, in <module>
  File "d:\arcgis\server\framework\runtime\arcgis\Resources\arcpy\arcpy\interop.py", line 103, in QuickImport
    raise e
  File "d:\arcgis\server\framework\runtime\arcgis\Resources\arcpy\arcpy\interop.py", line 100, in QuickImport
    retval = convertArcObjectToPythonObject(gp.QuickImport_interop(*gp_fixargs((Input, Output), True)))
  File "d:\arcgis\server\framework\runtime\arcgis\Resources\arcpy\arcpy\geoprocessing\_base.py", line 511, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (QuickImport).
Scrpt:
# Name: QuickImport_Ex_01.py
# Requirements: None
# Description: Imports KML file to a geodatabase
# Import system modules
import arcpy
arcpy.env.overwriteOutput = True
# Check out the Data Interoperability Extension
arcpy.CheckOutExtension("DataInteroperability")
# Set local variables
kmlPath = arcpy.GetParameterAsText(0)
#r"C:\Users\xchebrapp_\Documents\ArcGIS\Projects\Glint\Hult.kml"
output_gdb =  arcpy.env.scratchGDB
arcpy.AddMessage(str(kmlPath))
arcpy.AddMessage(str(output_gdb))
# Execute Quick Ixport
res= arcpy.interop.QuickImport(kmlPath, output_gdb)
print (res)
arcpy.AddMessage(str(res))
BruceHarold
Esri Frequent Contributor
Quick Import will always try to create a new file geodatabase and the scratch GDB already exists, try using another name and make sure it doesn't exist before running Quick Import.
Hari
Thanks  BruceHarold for suggestion.
I tried by giving a new gdb name but no luck.
added line os.path.join(arcpy.env.scratchFolder,"kml_1.gdb") which tried to create new GDB as
D:\arcgisserver\directories\arcgisjobs\qitest_gpserver\j9a143afdb97044e7a4d1b8fa4d727913\scratch\kml_1.gdb.
BruceHarold
My guess is Quick Import's input data type is not supported in the geoprocessing framework so you can try making an embedded Spatial ETL tool that accepts a file input.  However a workspace (geodatabase) output is not supported by server side geoprocessing, so you will need to write to a zipped file geodatabase and make its path an output.
TommiTerävä1
I looked into this and I've narrowed down the problem. I think the parameters somehow get mangled when inputted into the tool by gp_fixargs.
Here's a very basic python tool to test this issue:
# -*- coding: utf-8 -*-
import arcpy
import os
import traceback
from pathlib import Path
class Toolbox(object):
    def __init__(self):
        self.label = "Toolbox"
        self.alias = "toolbox"
        # List of tool classes associated with this toolbox
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        self.label = "Tool"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        params = [
            arcpy.Parameter(
                displayName="Input file",
                name="input_file",
                direction="Input",
                parameterType="Required",
                datatype="DEFile"
        return params
    def isLicensed(self):
        return True
    def updateParameters(self, parameters):
        return
    def updateMessages(self, parameters):
        return
    def execute(self, parameters, messages):
        ext_status = arcpy.CheckExtension("DataInteroperability")
        if ext_status != "Available":
            arcpy.AddError(f"Data Interoperability status: {ext_status}")
        else:
            arcpy.AddMessage("Data interoperability available")
        kmlPath = parameters[0].valueAsText
        arcpy.AddMessage(f"Input file: {kmlPath}")
        if not os.path.exists(kmlPath):
            arcpy.AddMessage("Source file doesn't exist")
            return
        arcpy.AddMessage("File contents:")
        with open(kmlPath, 'r') as file:
            for row in file.readlines():
                arcpy.AddMessage(row)
        arcpy.AddMessage("")
        output_dir = arcpy.env.scratchFolder
        if not os.path.exists(output_dir):
            arcpy.AddMessage("Creating destination folder")
            Path(output_dir).mkdir(parents=True, exist_ok=True)
        output_gdb = os.path.join(output_dir, "export.gdb")
        arcpy.AddMessage(f"Output gdb: {output_gdb}")
        try:
            res = arcpy.interop.QuickImport(
                Input=kmlPath,
                Output=output_gdb
        except Exception as e:
            arcpy.AddMessage(traceback.format_exc())
    def postExecute(self, parameters):
        return
And here's a very simple test file to reproduce the error with (test.geojson):
  "type": "Feature",
  "geometry": {
    "type": "Point",
    "coordinates": [125.6, 10.1]
  "properties": {
    "name": "Dinagat Islands"
Parameters used to publish webtool:
Messages when running locally:
Input file: C:\Users\_____\_____\Documents\ArcGIS\Projects\QuickImport\test.geojson
File contents:
  "type": "Feature",
  "geometry": {
    "type": "Point",
  "properties": {
Output gdb: C:\Users\_____\_____\Documents\ArcGIS\Projects\QuickImport\scratch\export.gdb
Messages when running published as Web Tool:
Input file: D:\arcgisserver\directories\arcgisjobs\quickimporttesttool_gpserver\ja6af2726b46a455296ce7e438a7d2492\scratch\test.geojson
File contents:
  "type": "Feature",
  "geometry": {
    "type": "Point",
  "properties": {
Output gdb: D:\arcgisserver\directories\arcgisjobs\quickimporttesttool_gpserver\ja6af2726b46a455296ce7e438a7d2492\scratch\export.gdb
  File "<string>", line 84, in execute
    raise e
TommiTerävä1
The root cause seems to be version incompatibility between ArcGIS Pro and the ArcGIS Enterprise environment where the tool is published. The code provided above works without issues in a more recent AE environment.
