Quick Export : can't save connection
1876
01-21-2025 09:59 AM
RémyGourrat
In Pro 3.3, i set a snowflake connection. Test is successfull.
But when i want to save, i have this message => Unable to store Connection Unable to add connection 'TEST'
Where Pro want to save it ? in a file ? do you know the location ?
Thanks for your help
Rémy
BruceHarold
Esri Frequent Contributor
Sorry I was not clear, if you start the Workbench application from the Analysis ribbon or ArcGIS program group then you'll see the Tools>FME Options>Default Paths dialog.
I think I see a bug though, while database connections persist for the Workbench app they do not for Quick Translate or the system Quick Import tool - I will investigate.
BruceHarold
Remy, I think this applies to Pro 3.3, if not please reply, but in the Tools>FME Options>Default Paths control you will see your connection storage options.  You must have permissions for these locations.
https://docs.safe.com/fme/2024.1/html/FME-Form-Documentation/FME-Form/Workbench/options_default_path...
RémyGourrat
Hi Bruce,
i don't have FME on my PC, just only ArcGIS Pro 3.3 with the DataInterop Extension.
i don't see a menu to access DataInterop FME path location in ArcGIS Pro,
have you an idea ?
BruceHarold
RémyGourrat
Hi Bruce,
Thanks for you work around by workbench, i can save in workbench. But it's not showed in quick export/import.
Esri support tell me it's a bug the issue closed in Pro 3.5
