Interop workbench returns 'No module named psycopg2'
1189
04-08-2025 02:47 AM
TomGeo
I am using sqlalchemy in a Python script that I created in VSC using a clone of the arcgispro-py3 environment.
When I run the code in VSC there is no problem. Now I need to have the code running in the Data Interop Workbench in a PythonCaller, and that's where I am facing
Python Exception <ModuleNotFoundError>: No module named 'psycopg2'
I went to check the Package Manager in ArcGIS Pro to check if the clone is set as the active environment and if I in fact have psycopg2 installed. Here a screenshot of the installed module
and here the sqlalchemy
Can I get some help why I am facing this issue, if the module is installed?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
BruceHarold
Esri Frequent Contributor
Tom in the Workbench application, open the Tools menu and in the Translation options set the Python compatibility to agree with Pro - the option named "Esri ArcGIS 3.11" or similar, depending on version.
