Export GPS coordinates of US Wildfire Activity Web Map
1338
09-14-2021 10:40 AM
AlbertKwok
I am wondering if it is possible to export GPS coordinate of US Wildfire Activity Web Map at https://www.arcgis.com/home/webmap/viewer.html?webmap=df8bcc10430f48878b01c96e907a1fc3.
Thanks very much in advance
Albert
by Anonymous User
Not applicable
If you use Pro, using the feature service URL add the layer into a map (below), then use the Features to GPX geoprocessing tool to create a GPS Xml file with .gpx extension.
If you want to transform your data or write to a different GPS format then Data Interoperability can come in handy with that.
AlbertKwok
Thanks, how do I Pro? I only see the measure tab on the right top with location option that will show the GPS position if I click on the map, see attached image. If I subscribe to developer, will I be able to code it using API to download the coordinates?
