Error 1000 when appending features to feature service
4780
09-01-2022 06:33 AM
StuartMoore
i'm getting an error 1000 in Data interop when trying to append a set of polygons to an ArcGIS Online feature service
the error is:
ArcGIS Online Feature Service Writer: 'addResults' error for a feature in 'Missing Buildings'. The error code from the server was '1000' and the message was: 'Invalid column name 'Shape_1'.
Invalid column name 'Shape_3'.
Invalid column name 'Shape_5'.
Invalid column name 'Shape_7'.
Invalid column name 'Shape_9'.
Invalid column name 'Shape_11'.
Invalid column name 'Shape_13'.
Invalid column name 'Shape_15'.'
ArcGIS Online Feature Service Writer: 0 features successfully written to 'Missing Buildings', but the server rejected the 1 features in the last request due to errors. See warnings above. Aborting translation
ARCGISONLINEFEATURES writer: A fatal error has occurred. Check the logfile above for details
i can export the same to a FGDB without issue so i'm stumped
any ideas?
JohannaKraus2
I was able to solve this by exporting the data I needed to append to a shapefile and then append it from the shapefile.
rsalvaleon_esri
@StuartMoore I found this Safe community question which has similarities to your issue.
https://community.safe.com/s/question/0D54Q000080hcL0SAI/dropped-and-renamed-fields-in-agol-now-the-...
Hopefully, the workaround will work for you.
For additional help reach out to ESRI Support and we could attempt to identify the root cause.
StuartMoore
thanks @rsalvaleon_esri i think i am going to have to raise a ticket with ESRI it looks like the issue is the geometry of my polygons because if i remove the geometry i can append the data to the feature service.
ive even checked the geometry and in data interop and it didnt have any issues so....
Stu
JohannaKraus2
Did you get an answer to this?  I'm running into the same issue with a polygon feature service.  Thanks.
JohannaKraus2
StuartMoore
nope i couldn't get it to work in FME i just used append in Pro 😞
