Workaround: Dashboard Mobile View: Cannot Rename Groups
1005
12-20-2024 12:09 PM
BryanGillis1
Hello, I was trying to rename some groups on a dashboard in mobile view, but I was unable to access more than the first three properly named groups. In the screenshot below you can see that those first three groups can be renamed and reordered, but there are 6 total that I cannot access when editing the dashboard because the spill-over scroll does not generate in edit-mode.
As a workaround, I renamed each group as a single letter and reorder, then renamed starting with the last group to prevent it from disappearing after being pushed outside of the view.
As you can see, this was likely the max number of groups this workaround would be successful with. Hopefully in the future, there will be an update to allow for either renaming/reordering groups (Column) in the view panel and/or the spill-over slider to generate in edit-mode.
JenniferAcunto
Click on any of the group names, so that it is blue. Then use your keyboard arrows (left and right) to scroll through the groups.
Keyboard Navigation Through GroupsKeyboard Navigation Through Groups
- Jen
