Which selector to use?
1489
12-16-2021 08:56 AM
RoseZhou2
Hello,
There is a filed in a map layer with random number values from 1 to 500+. Instead of list all the possible values in a category selector,  I would like to allow users to filter the map layer using that field by 1, 2, 3+. But I could not find the right operator.  Is it possible to do this in Dashboard of Portal 10.8.1?
Thanks
Rose
JayantaPoddar
The only way I can think of, is to create a new TEXT field to the hosted feature layer. Using Calculate Field, select appropriate values from integer field, and define the values '1', '2' and '3+' respectively.
In ArcGIS Dashboard, use this TEXT field for Category Selector.
Think Location
JayantaPoddar
How about a Number Selector?
Think Location
RoseZhou2
Thanks JayantaPoddar!
I am currently using a Number Selector and using "Slider" as the display type.
But users don't think that is user-friendly, they would like to use 3 checkboxes or a dropdown with 1, 2, 3+  as the options. But I can't find the right operator for that if I use a Category selector with those options.
Cheers
Rose
JayantaPoddar
Think Location
