Value of y-axis shows repetitive value
1176
02-09-2020 12:43 PM
MuhammadYasir
Hi there,
I am using serial chart on operation dashboard. There are few filters applied on the serial chart. I noticed that when samll value (typically between 0 and 1) shows on the serial chart, y-axis value repeats itself. For clarification, I have attached two pics that illustrates the issue.
Minimum and maximum value of axis is set on automatic.
Could you please help me in fixing the issue?
DanPatterson_Retired
looks like a decimal precision issue... can you not change the defaults or modify the formatting prefix by adding another #  ie #,###.##
MuhammadYasir
Thanks. It worked.
