Using embedded content in Operations Dashboard from more than one source
1499
10-23-2019 09:57 AM
AdrianWelsh
MVP Honored Contributor
I have an Operations Dashboard for ArcGIS that uses Embedded Content, that is fed from a feature layer (looking for one attribute - a youtube video link). This works fine, and I even have a list widget that uses an "action" to change the embedded content video.
I want to use a different list widget that is from a different feature layer to update this embedded content. Both feature layers use the exact same attribute field name and are both embedded youtube videos. Is there a way to do this?
When I try to do this, I get drop down fields for source and target:
And when I put in that attribute field name, the embedded content does not update properly (which I guess makes sense, I just want to know if this is possible).
Thanks!
