Use Arcade to Sum Results of Different Feature Classes and Display via Indicator
2312
6
10-30-2023 03:53 PM
HaydenHarrison1
Hello!
I am creating a dashboard in Portal that shows the total length of our four important pipe feature classes. I created an indicator for each of these layers showing the calculated sum of the Shape__Length field.
I now need a way to create a new indicator showing the simple sum of the four existing ones. How can I do this?
I did some research and started creating a data expression that looked back to the feature sets rather than the indicators. See below. However, this creates a number as an output and I need it to create a FeatureSet that an indicator can use. Please help!
var portal = Portal('portalnamehere')
//pressurized mains
var pm = Filter(
    FeatureSetByPortalItem(
        portal,
        'item id here',
        11,
        ['Owner_Entity','LifeCycleStatus','Shape__Length'],
        false
    "(Owner_Entity = 'Oklahoma City') AND (LIFECYCLESTATUS = 'ACTIVE')"
var sumPM = sum(pm,"Shape__Length")
//service lines
var sl = Filter(
        portal,
        'item id here',
        9,
        false
var sumSL = sum(sl,"Shape__Length")
//gravity mains
var gm = Filter(
        portal,
        'item id here',
        10,
        false
var sumgm = sum(gm,"Shape__Length")
//atoka
var at = FeatureSetByPortalItem(
        portal,
        'item id here',
        4,
        false
var sumat = sum(at,"Shape__Length")
var totalsum = sumpm + sumSL + sumgm + sumat
return totalsum/5280
jcarlson
MVP Esteemed Contributor
Hm. Well, AGOL lets you create a FeatureSet directly from a dict, but if you're in Enterprise you'll need to wrap it in Text().
Try "return FeatureSet(Text(fs_dict))" instead?
- Josh Carlson
Kendall County GIS
jcarlson
Easy enough! Just follow the JSON spec of a FeatureSet. Throw this in at the end of your expression.
var fs_dict = {
  fields: [{name: 'total_sum', type: 'esriFieldTypeDouble'}],
  geometryType: '',
  features: [{attributes: {total_sum: totalsum/5280}}]
return FeatureSet(fs_dict)
- Josh Carlson
Kendall County GIS
HaydenHarrison1
Hi Josh,
Thank you for the quick reply! A follow up question for you:
When I add the above code to mine, the output is the number of miles (which is correct); however, when I exit the data expression editor, it says "unable to execute Arcade script". I wondered if it was because the test was returning the "return totalsum/5280" rather than the "return FeatureSet(fs_dict)".
When I remove the "return totalsum/5280", I get the following error: Execution Error:Invalid Parameter
Attached is the code that returns the number rather than feature set. Thoughts?
Thank you again!!
var portal = Portal('portal name')
//pressurized mains
var pm = Filter(
        portal,
        'item name',
        11,
        false
//service lines
var sl = Filter(
        portal,
        'item name',
        9,
        false
//gravity mains
var gm = Filter(
        portal,
        'item name',
        10,
        false
//atoka
        portal,
        'item name',
        4,
        false
var totalsum = (sumpm + sumSL + sumgm + sumat)
var fs_dict = {
  geometryType: '',
jcarlson
Sorry, I should have mentioned, remove the existing "return totalsum/5280" line, then run it.
- Josh Carlson
Kendall County GIS
HaydenHarrison1
Unfortunately, I get the "Execution Error:Invalid Parameter" when I remove the existing "return totalsum/5280".
I am new to arcade so I'm unsure what exactly it means by "Invalid Parameter". Any insight is appreciated.
Hayden
jcarlson
- Josh Carlson
Kendall County GIS
HaydenHarrison1
It worked! Thank you!!
