Update to Dashboard datasource schema??
1352
08-20-2024 03:54 PM
TimWarfe_MSC
Hi guys,
I've updated the map/feature service schema since creating a dashboard.  Turned a couple date fields from 'String' to 'Date Only' types within the datasource layer.
I don't want to have to recreate the dashboard.  How do I update the schema within the dashboard settings?  (I can't even select or view the fields I changed now within the dashboard)
Any help would be much appreciated.
Regards
Tim
TimWarfe_MSC
Update - I've been able to include the new schema fields into the Dashboard.   I found that "Date Only" field type didn't allow the fields to be seen in the Dashboard.   "Date" (Date/Time) field type allowed the fields to be seen and used within the dashboard.
No ArcGIS assistant was required on this occasion.
AlexQuintero1
Have you tried using the ArcGIS Online Assistant? https://ago-assistant.esri.com/
TimWarfe_MSC
Thank you. Can you please describe the steps I need to undertake?
TimWarfe_MSC
