Table Widget (Wrap Text)
6423
12
01-18-2022 02:43 PM
MatthewThomas1
Ops Dashboard now has the Table Widget which is great. Is there a way to use Arcade to allow the table to "Wrap Text". It seems like the table is designed to display a set amount of characters and not a field for longer comments.
see comments that has the etc.. It does not wrap the text.see comments that has the etc.. It does not wrap the text.
MarcelBeckmann
It is a little late, but in case someone else is reading this.
You have to insert the code from GFernando above the configuration of your cells.--> Bevore the return.
Exchange the long string with $datapoint.YOUR_VALUE
The wraped Text is then stored in the variable "wrapText" and you can use it in the definition of your cells.
var longText =$datapoint.uniqueid
// Split longText into individual words
var longTextarray = Split(longText, ' ')
// Characters per line before line break
var lineLength = 50
var wrapText = ""
var words = 0
var characters = 0
while(words < Count(longTextarray)){
// Count number of characters per line
characters += Count(longTextarray[words] + " ")
// When number of characters exceed lineLength add a line break, otherwise add a SPACE
wrapText += longTextarray[words] + When(characters >= lineLength, "<br>", " ")
// When number of characters exceed lineLength, reset characters variable back to 0
characters = When(characters >= lineLength, 0, characters)
words += 1
return {
  cells: {
    uniqueid: {
    displayText: wrapText,
    hoverText: $datapoint.uniqueid,
    textColor: '',
    backgroundColor: '',
    textAlign: 'left',
    iconName: '',
    iconAlign: '',
    iconColor: '',
    iconOutlineColor: ''
Deastman
Nice one Gee!
I just used this in a link chart coming off an ArcGIS Knowledge.
For some reason the <br> didn't work... so subbed in textFormatting.newLine. Worked a treat.
KevinMayall
I was just working on this a few days ago.  Great code.  Thank you!
Kevin
