show icon with empty (null) data in field
1577
09-07-2023 09:02 AM
dwold
I have assigned icons to values. However, some records have null or empty values for that field. I would still like to render an icon for those empty records. Any suggestions on how to do this? My goal is to render the gray icon if the record is empty/null.
I tried but it isn't working:
JenniferAcunto
Instead of having the Arcade display it, you will need to use the No Data message. Add an icon to the No Data message using HTML and an SVG code.
<div style="display:flex; gap:2px; height:200px; justify-content:center"><svg version="1.1" viewbox="32 40 447.84 440" xmlns="http://www.w3.org/2000/svg"> <g fill="#808080"> <path d="m416 96c-0.45703 0-0.91406-0.011719-1.3672-0.039062-0.68359 1.9258-1.6055 3.7617-2.75 5.457 4.3242 7.043 5.2969 15.641 2.6562 23.473 3.7734 2.8555 6.6094 6.7656 8.1484 11.238 5.8047 0.55859 11.289 2.9258 15.68 6.7656 7.9609-0.90625 11.934-4.5078 11.973-4.5508h0.003906c1.5-1.5 3.5352-2.3438 5.6562-2.3438h16c1.1211 0 4.1016-3.3164 6.1562-13.57 0.875-4.582 1.4375-9.2188 1.6836-13.879l-43.039-24.598c-2.1055 3.6602-5.1328 6.6992-8.7852 8.8164-3.6523 2.1133-7.7969 3.2266-12.016 3.2305zm32 16c0 3.2344-1.9492 6.1523-4.9375 7.3906-2.9922 1.2383-6.4297 0.55469-8.7188-1.7344s-2.9727-5.7266-1.7344-8.7188c1.2383-2.9883 4.1562-4.9375 7.3906-4.9375 2.1211 0 4.1562 0.84375 5.6562 2.3438s2.3438 3.5352 2.3438 5.6562z"></path> <path d="m427.16 173.6c4.1562-3.082 5.8594-8.4844 4.2344-13.391-1.6289-4.9102-6.2227-8.2188-11.395-8.2109-0.82422 0-1.6445 0.082031-2.4531 0.24609-2.3477 0.46875-4.7852-0.14062-6.6406-1.6602-1.8516-1.5195-2.9258-3.7891-2.9258-6.1875 0-0.19141 0.007812-0.38281 0.019531-0.57422h-0.003906c-0.070313-3.6523-2.6172-6.7852-6.1758-7.6055-2.668-0.62891-4.832-2.5781-5.7305-5.1719-0.89844-2.5898-0.40234-5.4609 1.3047-7.6055 3.9766-4.9883 3.332-12.215-1.457-16.422-1.8242-1.6172-2.8086-3.9805-2.6758-6.4141 0.13281-2.4336 1.3672-4.6719 3.3516-6.0859 2.1328-1.4844 3.3984-3.9219 3.3867-6.5195-0.007812-0.375-0.039062-0.74609-0.10156-1.1172-0.44531-3.0508 0.90625-6.0898 3.4727-7.8047s5.8906-1.8008 8.5391-0.22266c1.2344 0.75 2.6484 1.1445 4.0898 1.1445 4.418 0 8-3.582 8-8s-3.582-8-8-8h-8c-4.418 0-8-3.582-8-8v-16l-19.199 14.398c-0.15234 0.11328-0.30469 0.21875-0.46484 0.32422-6.3359 4.1172-12.336 10.578-12.336 13.277-0.003906 2.5938 0.84766 5.1172 2.4141 7.1797 1.8281 2.4219 2.1289 5.6719 0.77734 8.3867-1.3555 2.7188-4.125 4.4336-7.1602 4.4336-3.957-0.019531-7.6641 1.9141-9.9102 5.168-2.25 3.2539-2.7422 7.4102-1.3203 11.102 1.3477 3.5508 0.011719 7.5664-3.1992 9.5977-3.3477 2.1016-5.4414 5.7148-5.5938 9.6641-0.15234 3.9453 1.6562 7.7148 4.8281 10.066 2.0156 1.5117 3.1992 3.8828 3.1992 6.3984 0 2.5195-1.1836 4.8906-3.1992 6.4023-3.043 2.25-4.8398 5.8125-4.8398 9.5977 0 3.7891 1.7969 7.3477 4.8398 9.6016 2.0156 1.5117 3.1992 3.8828 3.1992 6.3984 0 2.5195-1.1836 4.8906-3.1992 6.4023-2.5625 1.8906-4.2578 4.7305-4.7148 7.8828-0.45312 3.1523 0.37109 6.3555 2.293 8.8945 1.832 2.4219 2.1328 5.6719 0.78125 8.3906-1.3555 2.7188-4.1289 4.4336-7.1641 4.4336-6.6367-0.003906-12.02 5.3672-12.031 12 0.003906 3.0352-1.7109 5.8125-4.4258 7.1719-2.7148 1.3594-5.9648 1.0664-8.3906-0.75781-2.543-1.9219-5.7461-2.7461-8.8984-2.293-3.1523 0.45703-5.9922 2.1562-7.8828 4.7188-1.5117 2.0117-3.8828 3.1992-6.4023 3.1992-2.5156 0-4.8867-1.1875-6.3984-3.1992-1.9961-2.6992-5.0352-4.4336-8.375-4.7773-3.3359-0.34375-6.6641 0.73828-9.168 2.9766-1.9727 1.7539-4.6875 2.4219-7.25 1.7852-2.5625-0.64062-4.6445-2.5-5.5664-4.9766-1.3594-3.7227-4.4766-6.5234-8.3164-7.4883-3.8438-0.96484-7.9102 0.039063-10.867 2.6797-1.9727 1.7539-4.6875 2.4219-7.25 1.7852-2.5625-0.64062-4.6445-2.5-5.5664-4.9766-1.3594-3.7227-4.4766-6.5234-8.3164-7.4883-3.8438-0.96484-7.9102 0.039063-10.867 2.6797-1.9727 1.7539-4.6875 2.4219-7.25 1.7852-2.5625-0.64062-4.6445-2.5-5.5664-4.9766-1.75-4.6992-6.2266-7.8242-11.242-7.8477-3.7891-0.003906-7.3516 1.7891-9.6016 4.8398-1.5078 2.0117-3.8789 3.1992-6.3984 3.1992s-4.8906-1.1875-6.3984-3.1992c-2.25-3.0508-5.8125-4.8438-9.6016-4.8398-5.0117 0.023438-9.4883 3.1484-11.242 7.8438-0.91797 2.4766-3 4.3398-5.5664 4.9805-2.5625 0.63672-5.2773-0.03125-7.25-1.7891-2.9531-2.6367-7.0234-3.6406-10.863-2.6758-3.8438 0.96094-6.957 3.7656-8.3203 7.4844-0.91797 2.4766-3 4.3398-5.5664 4.9805-2.5625 0.63672-5.2773-0.03125-7.25-1.7891-3.2344-2.8867-7.7773-3.7969-11.875-2.375-4.0977 1.418-7.1055 4.9453-7.8594 9.2188-0.37891 2.1445-1.6211 4.043-3.4336 5.2539-1.8164 1.2109-4.043 1.6289-6.1719 1.1562-0.85547-0.19141-1.7266-0.28906-2.6016-0.28906-6.625 0.007812-11.992 5.375-12 12-0.003906 2.5938 0.84375 5.1172 2.4141 7.1797 1.8281 2.4219 2.1289 5.6719 0.77734 8.3867-1.3555 2.7188-4.125 4.4336-7.1602 4.4336-5.1797-0.023438-9.7852 3.2812-11.422 8.1953-1.6328 4.9141 0.070313 10.32 4.2305 13.406 2.0117 1.5078 3.1992 3.8789 3.1992 6.3984s-1.1875 4.8906-3.1992 6.3984c-4.1562 3.082-5.8594 8.4844-4.2344 13.391 1.6289 4.9102 6.2227 8.2188 11.395 8.2109 3.0352-0.003906 5.8125 1.7109 7.1719 4.4258 1.3594 2.7148 1.0664 5.9648-0.75781 8.3945-2.0195 2.668-2.8242 6.0625-2.2188 9.3555 0.60547 3.293 2.5664 6.1797 5.4062 7.957 3.2109 2.0312 4.5469 6.043 3.1992 9.5977-1.1523 2.9883-1.0547 6.3164 0.26953 9.2305 1.3281 2.918 3.7695 5.1797 6.7773 6.2773 2.4766 0.92188 4.3398 3.0039 4.9766 5.5664 0.64062 2.5625-0.027344 5.2773-1.7852 7.25-2.2383 2.5039-3.3164 5.832-2.9766 9.168 0.34375 3.3398 2.0781 6.3789 4.7773 8.375 2.0156 1.5117 3.1992 3.8828 3.1992 6.3984 0 2.5195-1.1836 4.8906-3.1992 6.4023-2.6211 1.9531-4.3281 4.8906-4.7305 8.1328-0.39844 3.2422 0.53906 6.5078 2.6016 9.043 2.0664 2.5352 5.0742 4.1133 8.332 4.3789 3.2539 0.26172 6.4805-0.81641 8.9219-2.9844 2.8789-2.5625 7.1797-2.707 10.223-0.34375 4.3359 3.375 10.102 4.2891 15.266 2.4219 5.168-1.8711 9.0117-6.2578 10.184-11.629 1.1758-5.3672-0.49219-10.961-4.4062-14.812-2.6328-2.5938-3.1484-6.6523-1.2461-9.8203 1.9023-3.168 5.7305-4.6211 9.2578-3.5117 1.5391 0.48437 3.1445 0.72656 4.7578 0.72656 4.0312-0.015625 7.9062-1.543 10.863-4.2812 2.9531-2.7383 4.7695-6.4883 5.0898-10.508 0.22656-3.0469 2.1719-5.6953 5.0117-6.8281 2.8359-1.1367 6.0703-0.55469 8.3359 1.5 3.457 3.1172 8.0977 4.5742 12.719 3.9922 4.6172-0.58594 8.75-3.1602 11.316-7.043 1.4844-2.2305 3.9844-3.5742 6.6641-3.5742s5.1797 1.3438 6.6641 3.5742c2.9609 4.4766 7.9688 7.168 13.336 7.168s10.375-2.6914 13.336-7.168c1.4844-2.2305 3.9844-3.5742 6.6641-3.5742s5.1797 1.3438 6.6641 3.5742c2.9609 4.4766 7.9688 7.168 13.336 7.168s10.375-2.6914 13.336-7.168c1.4844-2.2305 3.9844-3.5742 6.6641-3.5742s5.1797 1.3438 6.6641 3.5742c2.5703 3.8867 6.707 6.457 11.332 7.0391 4.6211 0.58594 9.2695-0.87109 12.727-3.9922 2.2695-2.0469 5.5078-2.6211 8.3398-1.4805 2.8359 1.1367 4.7734 3.793 4.9961 6.8398 0.17188 2.3789 0.88281 4.6914 2.0859 6.7539 1.4336 2.4766 1.4336 5.5312 0 8.0117-1.8828 3.2578-2.5547 7.0742-1.9023 10.777 0.65234 3.707 2.5898 7.0625 5.4688 9.4805 2.8828 2.418 6.5234 3.7461 10.285 3.7461 3.7656 0 7.4062-1.3281 10.289-3.7461 2.8789-2.418 4.8164-5.7734 5.4688-9.4805 0.65234-3.7031-0.019531-7.5195-1.9023-10.777-1.4297-2.4766-1.4297-5.5312 0-8.0078 2.4414-4.2266 2.8203-9.3398 1.0273-13.883-1.125-2.8438-0.52734-6.082 1.5352-8.3398 2.0625-2.2578 5.2305-3.1406 8.1641-2.2773 1.1133 0.32812 2.2656 0.5 3.4219 0.50391 5.7773 0 10.734-4.125 11.785-9.8047 0.60156-3.2617 3.1523-5.8086 6.4102-6.4141 5.6797-1.0469 9.8047-6.0039 9.8047-11.781 0-0.875-0.097656-1.7461-0.28906-2.6016-0.47266-2.1289-0.054688-4.3555 1.1523-6.1719 1.2109-1.8125 3.1094-3.0547 5.2578-3.4375 5.7188-1.0078 9.8867-5.9805 9.8789-11.789 0-0.875-0.097656-1.7461-0.28906-2.6016-0.47266-2.1289-0.054688-4.3555 1.1523-6.1719 1.2109-1.8125 3.1094-3.0547 5.2578-3.4375 4.2695-0.75391 7.8008-3.7578 9.2188-7.8555 1.4219-4.0977 0.51172-8.6445-2.375-11.879-1.7578-1.9727-2.4258-4.6875-1.7852-7.25 0.63672-2.5625 2.5-4.6484 4.9766-5.5664 3.7188-1.3594 6.5234-4.4766 7.4844-8.3203 0.96484-3.8398-0.039063-7.9102-2.6758-10.863-1.7578-1.9727-2.4258-4.6875-1.7852-7.25 0.63672-2.5625 2.5-4.6484 4.9766-5.5664 4.6953-1.75 7.8203-6.2266 7.8438-11.238 0.003906-3.7891-1.7891-7.3516-4.8398-9.6016-2.0117-1.5078-3.1992-3.8789-3.1992-6.3984s1.1875-4.8906 3.1992-6.3984c3.0469-2.2539 4.8438-5.8164 4.8438-9.6016s-1.7969-7.3477-4.8438-9.6016c-2.0117-1.5078-3.1992-3.8789-3.1992-6.3984s1.1875-4.8906 3.1992-6.3984z"></path> <path d="m96 456v-1.0156c-2.25-0.57422-4.4297-1.3984-6.5-2.4531-2.8984 1.5938-6.0586 2.6562-9.332 3.1445l4.5664 18.262c0.88281 3.5625 4.0859 6.0664 7.7539 6.0625h27.512v-3.7188l-20.438-13.625c-2.2266-1.4844-3.5625-3.9805-3.5625-6.6562z"></path> <path d="m336 456v-17.012c-5.2461 1.3477-10.754 1.3477-16 0v16.027l4.7305 18.926v-0.003906c0.88672 3.5664 4.0859 6.0664 7.7578 6.0625h27.512v-3.7188l-20.438-13.625c-2.2266-1.4844-3.5625-3.9805-3.5625-6.6562z"></path> <path d="m89.934 200.64c1.5234 0.33203 3.0156 0.78906 4.4648 1.3711 3.3984-10.328 1.3164-21.676-5.5234-30.129s-17.504-12.855-28.312-11.688c-10.812 1.168-20.289 7.7461-25.164 17.465 10.352-2.7969 21.34-2.0547 31.223 2.1094 9.8789 4.1641 18.086 11.512 23.316 20.871z"></path> </g></svg>
<div style="margin-bottom:100px; margin-left:100px; margin-right:100px; margin-top:100px"><span style="font-size:48px"><strong>No Data</strong></span></div>
</div>
- Jen
JenniferAcunto
</div>
- Jen
dwold
@JenniferAcunto thank you!!
