Serial chart display only on demand
393
07-14-2022 12:31 AM
FilippoTorda
Hi everyone, I have a display problem on a Dashboard in ArcGIS Enterprise. In the side panel I have a series of selectors that filter a very large dataset, once the search parameters have been selected, the results are shown in a list and in a serial chart.
The problem arises when this resulting data is a lot, the loading of the chart hangs.
Is there the possibility to "activate" the display of the chart only on request? My idea is to put a counter, see how many records there are and if there are not many show the chart, otherwise show only the list which has no problems even in the case of very large datasets.
Thanks to everyone and have a nice day
GregKeith
Occasional Contributor III
You may be able to do this with an arcade expression as the data source for the chart
