Separating Search Bar from Scalebar in ArcGIS Dashboards
598
01-23-2025 08:28 PM
Earth_DayCleanup
Hi everyone,
I’m working on a map in ArcGIS Dashboards, and I’m running into an issue with the Search bar placement. When I configure the map settings, the Search bar appears grouped with the Scalebar and other tools. However, I’d like to separate the Search bar to make it a standalone element for better visibility and usability.
Here’s what I’ve tried so far:
  1. I enabled the Search option in the map’s settings (via the Dashboard).
  2. Adjusted the General, Map actions, and Layer actions settings, but couldn’t find a way to move the Search bar out of the Scalebar grouping.
  3. Looked for a way to add a separate search widget in the Dashboard, but couldn’t locate one (I only see options like Legend, Filters, etc.).
Ideally, I’d like the Search bar to be displayed either independently at the top of the map or as a separate tool that isn’t tied to the Scalebar. In the screenshot I attached you can see the dropdown menu of it as well.
If anyone has experience with customizing tool placement in Dashboards or knows a workaround, I’d greatly appreciate your advice. Thanks in advance for your help!
clt_cabq
Unfortunately this is one of those things that ESRI decided to change that I don't think provides any great advantage or utility and not provide any options, you're kind of stuck with how the tools selected in your configuration are packaged together as far as I can tell. This is a recent change, and confused several of my end users who thought the map tools in the dashboards I've set up were removed. You have a little more flexibility with some of this in using Experience Builder but that's another kind of pain in the butt if you are really wanting to work with dashboards. Depending on the functionality you are looking for, some of the widgets offer a separate search bar that appear in them, but those searches are really focused on what is in widget, such as a list.
RachelGodinho2
Following the June 2025 ArcGIS Online update:
  • The "More tools" dropdown menu in the top right corner is now expanded on launch, making the tools (including the search tool) more readily apparent.
  • The Measurement tools have been separated from the rest of the tools and placed in the top left corner of the screen.
  • The scalebar remains separated on the bottom left of the screen.
^ In this screenshot, all tools were toggled on / enabled in the Dashboard settings.
^ In this screenshot, only "Search" was toggled on in the settings and one can see the search icon is not housed in the "More tools" dropdown menu.
