Plot data Timeseries from .cvs file into Dashboard
1401
08-11-2022 06:50 AM
AndreaPaindelli
Good morning,
I'd like to know if there is a way to visualize non geo-referenced data into Dashboard.
I have time series data in .csv format and I'd like to plot and show this data into Dashboard.
Is this possible?
Thank You in advance,
Andrea
Tags (3)
JenniferAcunto
Yes, it is possible. You just need to publish your CSV has a hosted table.
Go to your Content and click 'New Item'.
Browse to your CSV and select it. When asked to select your location settings, click the dropdown and select 'none- add as a hosted table'.
Once your table has been published, open up a new dashboard.
When you add a dashboard element, it will ask you to select a data layer, simply choose the hosted table you just created.
- Jen
