Operations Dashboard: related data and dynamic filtering
1576
05-25-2018 08:30 AM
AlfonsoDodero
Hi everyone, I'm new with Operations Dashboard for ArcGIS. I would like to know if is possible to build an indicator based on elements contained in a related table filtered on the current map view. Just like it’s possible to set an action with a non-related layer. Thanks!
ArnaudBrival
Same question:  I have a summary dashboard of marine park violation reports with several details widgets, each containing the info of group repeats (i.e. offenders, evidences, witnesses etc..).
Is there anyway to create dynamic actions (i.e. filtering) when the associated case is selected on the feature layer.  Or even better: a filter allowing to display the related data only of features within the map extent ?
Thanks a lot in advance for the help.
Arno
NicoKroes2
I found this ESRI Support Article: How To: Show related records in Operations Dashboard for ArcGIS. I am not sure if this will help you out, but it looks like it shows you how to display records from a related table in the list and details widget in ArcGIS Operations Dashboard. I hope this helps.
