operations dashboard freezes
1706
11-25-2016 02:49 AM
PhilipGlasner1
Hi there,
I am using lots of queries in Ops Dashboard (50+). When I try to open the view, ops dashboard freezes. Any suggestions?
Philip
Tags (1)
JayantaPoddar
Are you using Op. Dashboard in a physical machine or VM? Does the view open at all or it just crashes at the end?
Try turning off Accelerated Display even if the dashboard is installed in a physical machine.
Problem: Operations Dashboard for ArcGIS crashes when running on a virtual machine
Think Location
PhilipGlasner1
Physical machine. The view opens but freezes during the initialization (blue dots on top do not move anymore). I tried to use your advice about Accelerated Display but no change.
