Operations Dashboard Bug? - Labels in Map Prevents Dashboard Browser View from Loading
18751
23
09-12-2014 08:33 AM
DanAllen
  1. Create ArcGIS.com map with a feature service hosted in ArcGIS.com
  2. Create Operation Dashboard View (desktop windows)
  3. Log into ArcGIS.com, and Open web version of Dashboard in Browser - Everything works great.
  4. Turn on labels in ArcGIS.com map
  5. Open Web version of Dashboard in Browser - Map never loads
  6. Turn Labels off In ArcGIS.com Map
  7. Open Web version of Dashboard in Browser - Map Still does not load
Is anyone else able to reproduce this error?
Dan
Tags (1)
FrancescaGonzalez
Thanks Crhis, I understand perfect, but in collector the same thing happens?
Https://www.screencast.com/t/6wjfeyA1B6
KevinBurke
Hi Francesca,
My name is Kevin and I work on the Collector team. With regards to your last post, I was able to view your video.
The reason why your labels and symbology aren't displaying when the map is opened in Collector is because the current version of Collector doesn't support labels and also doesn't support Arcade Expressions, which your symbology is based off of.
We're currently working on the next generation version of Collector that we should be releasing for beta in the upcoming months. I am not sure that labels or support for Arcade expressions will make it into the first beta, but we plan on releasing a series of beta versions throughout the next several months that should address those as well as many other current limitations. Please keep an eye out for any upcoming blog posts regarding this new version of Collector and for more information about it.
Thank you.
-Kevin
FrancescaGonzalez
AllanLambert
Labels in Dashboard.  My workaround in the new online Dashboard was to add my map with labels as Embedded Content URL instead of adding as a Map.  I don't know if Embedded Content has always been in the dropdown with graph, pie chart, map, serial chart, indicator, but it works.  I can't tell the difference between adding as a Map vs adding as Embedded Content.  I can also use the Batch Editing widget in the map within Dashboard.
