Need help with arcade expression in Dashboard
583
02-10-2025 09:49 AM
KelvinNganga
I have a layer with monthly offertory from 2020 to 2025 stored in rows. Additionally, I have a summary table with the total offertory for each year.
I want to create an ArcGIS Dashboard that:
  1. Displays the total sum of offertory on an Indicator widget.
  2. Allows users to filter by year using a Category Selector.
  3. When a year is selected, it compares the total offertory for the selected year with the previous year and displays the growth or reduction in a bottom text, showing whether it’s positive or negative growth
Below is one I came up with, but the bottom text is using the sum offertory to subtract from the selected year instead of using the previous year. eg when I click 2024 on the category selector I want the indicator to show the sum offertory of year 2024 and the +ve or -ve change from the previous year
// Calculate the difference between the current and previous year
var currentYearTotal = $datapoint["SUM_Yearly_Offertory"];
var previousYearTotal = $reference["SUM_Yearly_Offertory"];
var difference = currentYearTotal - previousYearTotal;
// Calculate absolute difference and percent change
var absoluteDifference = Abs(difference);
var percentChange = IIf(previousYearTotal == 0, 0, (difference / previousYearTotal) * 100);
// Set default text color and symbol
var bottomTextColor = "black";
var bottomTextSymbol = "";
// Determine if the change is positive or negative
if (difference > 0) {
  bottomTextColor = "green";  // Positive growth
  bottomTextSymbol = "▲";
} else if (difference < 0) {
  bottomTextColor = "red";  // Negative growth
  bottomTextSymbol = "▼";
// Return formatted text for the Indicator widget
return {
  middleText: "Ksh " + Text(currentYearTotal, "#,###"),  // Display current year total
  middleTextColor: "black",
  middleTextMaxSize: "large",
  bottomText: bottomTextSymbol + " " + Text(absoluteDifference, "#,###") +
              " (" + Round(percentChange, 2) + "% Change)",
  bottomTextColor: bottomTextColor,
  bottomTextMaxSize: "medium"
