Multiple tabs from same source: remove selection between them
683
11-06-2023 05:13 AM
mikaël
I have a dashboard with 3 tables generated from the same arcade source, all shown as different tabs. Each table have different filters and each have a filter on 2 other widgets (list and details) based on a different column (date and globalid).
I find it confusing that you can select something in tab 1, have the related information display, go to tab 2, select something else and have it display, but the selection is still active in tab 1. So if you deselect something in tab 2, the related widgets will revert back to the selection from tab 1 but the user is still on tab 2.
Is it possible to remove selection from tab 1 when a selection is made in tab 2? This is all from the same source. I can't activate the "render only when filtered" option, because then it just won't work for the 3 tabs.
Thanks!
