Multiple Series in a Line Graph
1401
11-20-2022 06:21 PM
LowellHood
Hello,
I am trying to create a line graph in ArcGIS Dashboards that shows a monthly crime trend. I am trying to make each line a different year with month on the x-axis and incident count on the y-axis, similar to this chart:
However, in Dashboards the closest I can get is this:
Is there a way to format it like the first chart? Any help would be appreciated. Please let me know if you need additional information.
Thank you
JenniferAcunto
You cannot use a date field to get the look you want. If you reformat your data to include the following fields: Month, Year, and Value.
Then use the month field as your category field and split it by year.
To ensure the order of the months is correct, I would recommend using the numeric value and then using the categories label to set the month text.
- Jen
JenniferAcunto
- Jen
LowellHood
@JenniferAcuntoThank you for the reply! I ended up doing what you suggested and it worked. I really appreciate the help!
