Map grayed out in Actions-Target
1391
07-21-2020 12:45 PM
by Anonymous User
Not applicable
I am building a simple dashboard with several different elements.  I've gotten the widgets to filter based on a pie chart but cannot get the map to filter based on the same pie chart.  For example, select South division in the pie chart filter and the various widgets change but the map does not pan to the South division area.
Secondly, when I set up actions on the pie chart, the map is grayed out so it is not selectable.
Any thoughts as to how to synch the pie chart selector and the map?
Thanks!
PeterGoedbloed1
Same issue here. No one replied though. Did you solve this? Did you have null values in your data?
