Issue with category selector
3023
01-29-2024 09:18 AM
Katie_Clark
MVP Regular Contributor
Tl;DR: The main issue is that the category selector (select multiple) gets stuck on "loading" when I try to configure it to have flash, pan, or zoom actions.
Background/Detail: I am working with a dataset that currently has ~100,000 records. Each record has a value in the "Source" attribute with the state name or the federal data source, and so I want to set up a category selector in my dashboard that allows the users to either select all state data through a "Select All" (which filters out the federal data from the map) or the user can select various states individually and see those features on the map. I want my map to pan/zoom to the features when the user makes a selection.
The category filter keeps getting stuck on "loading" and won't accept user interaction.
This is what I want it to look like:
The category selector is configured to display categories from grouped values, based on this filter to remove the federal datasets:
The category selector works IF I only have the Filter action. If I try to add Flash, Pan, or Zoom in addition, it gets stuck on the "loading" state.
Any ideas on why this is happening and possible workarounds?
Thanks!!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Jaredaustin813
Having a similar issue, dashboard allowed zoom option on the category selector but now it is no longer there. Was having the same loading problem only to realize it was due to the fact that when updating my data, I previously was zooming to features that used grouped values which apparently is no longer supported? For whatever reason after updating the dashboard this zoom option is no longer there. 52390afd-94b5-4009-b025-cedf55b27c69.jpgGrouped values875f0123-3f8a-4bcf-a9e4-f545206d5c8c.jpgShowed zoom optionEsriCapture.PNGZoom option is now gone??
ToddSomer
Having the same issue, has this been resolved?
RyanKelley_NA
Did anyone figure out what is going on with this?  I was thinking it was something related to using Arcade in the dashboard to manipulate the data prior to it being used by the dashboard but I am not 100% sure on that.
PaigeRusso
I am having this issue also. Did anyone figure out a workaround?
