Is it possible to export features in the new Operations Dashboard?
743
01-30-2018 10:25 AM
JimO_Leary2
I can filter features on the map by attribute and map extent. Is it possible to export those features and their geometry?
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Jim,
Not with the operations dashboard.  I would recommend looking at using the Web AppBuilder with the Dashboard theme.  This is a similar theme to the Operations Dashboard.  You can also add widgets, such as the Analysis Widget.  There is an Extract Data tool within the Analysis widget.
