Indicator - show 0 AND icon instead of "no data" when no records match filter
1692
07-20-2023 12:19 PM
LS-SD
I have an dashboard indicator that displays sum of a field (bctotal). When there are no records, it shows "no data." I would like it to show 0 (zero) AND the icon. If I change the label to 0 for no data, the icon is not present. I tried using advanced formatting to check for null and return 0, but that didn't work. Help?
return {
textColor: '#ffffff',
backgroundColor: '#38a800',
middleText: Iif(IsEmpty($datapoint["sum_bctotal"]), 0, $datapoint["sum_bctotal"]),
middleTextColor: '',
middleTextOutlineColor: '',
middleTextMaxSize: 'large',
bottomText: 'CONTAINERS',
bottomTextColor: '',
bottomTextOutlineColor: '',
bottomTextMaxSize: 'small',
iconName: 'icon1',
iconAlign: 'left',
iconColor: '',
iconOutlineColor: ''
Indicator currently shows
but would like it to look like this, except 0 instead of 58
AshliPrejean
We would like this option as well. We have multiple indicators that use different statistics. One is SUM and the other is COUNT. The count indicator shows a zero value and the icon if the date filter has no records for that date. I assume this is because it always has something to count regardless of value, but shouldn't the date selector be filtering it and if there is nothing matching today's date, the "No data" text should be all that appears? Even selecting "Render when filtered", it still shows the zero count and icon.
On the other hand, the sum indicators (also tested with the other stat options) show the "No data" text (or our no data customized text) both when there is no data for that date selected AND when we select "Render when filtered". The only difference is the statistic type.
I'm sure getting into the Advanced Formatting this could be worked around, but with so many options, its strange that this is the behavior.
For a public facing dashboard the inconsistency may be confusing.
RachealFarinloye
I am experiencing this same issue on a COUNT statistics, it makes the interface confusing for a public dashboard
is there any work around yet? @esri
santa_g
Any updates ?
MarkGo
This is truly frustrating. It destroys the aesthetics / functionality of indicators to not have a "fallback" value you can configure, while still keeping the rest of the indicator formatting.
