Indicator Element not filtering correctly
371
10-09-2024 06:57 AM
SLouq
by MVP Alum
I have put together a projects dashboard which has an indicator element in it to show the currently Active Projects for my Department. It works correctly when the dashboard is shared through my organization but it doesn't work correctly when I change the share settings to public. Why is this happening?
I have a bunch of filters set for the element so it knows when a project is active or not. Could this be causing the issue?
