How to concatenate fields to show Graph...
2445
03-24-2022 02:19 PM
MiltonSolano
Hi Folks,
I have this expression on my map popup window to show in one field, the content from 8 different fields (see screenshot below):
Trim(Concatenate([$feature["COD_A"],
$feature["COD_B"],
$feature["COD_D"],
$feature["COD_L"],
$feature["COD_M"],
$feature["COD_N"],
$feature["COD_P"],
$feature["COD_Q"],
$feature["COD_R"],
I'm trying to create a graph on my dashboard to show exactly this expression (See the screenshot with the Pie Chart as example). The graph will show how many variations of the codes are in the database (ex. LR - 10, BQ-5, RB-2, D-15, etc.). The field expression is not available in Dashboards, so I can't use the expression. I tried Data Expressions but I can't figure out how to do it.
Can you help me to figure out how to achieve this? thanks in advance!
Milton
jcarlson
Data Expressions can be a lot to wrap your head around, but it's totally the way to go. This will allow you to create a "virtual" field in your data that a chart can interact with.
var fs = FeatureSetByPortalItem(
    Portal('your-portal-url'),
    'itemid of feature service',
    0, // or whatever the layer index
    false
// Get existing fields
var fields = Schema(fs)['fields']
// Push new feature into field array
Push(
    fields,
    {name: 'concat_vals', type: 'esriFieldTypeString'}
// Create dictionary to hold output features
var out_dict = {
    fields: fields,
    geometryType: '',
    features: []
// Iterate over features, concatenating fields and pushing into feature array
for (var f in fs){
    // Get feature as dict
    var feat = Dictionary(Text(f))
    // // Values to concatenate
    var concat_arr = [
        f['COD_A'],
        f['COD_B'],
        f['COD_D'],
        f['COD_L'],
        f['COD_M'],
        f['COD_N'],
        f['COD_P'],
        f['COD_Q'],
        f['COD_R']
    // // Concatenate values to string
    var concat_str = Trim(Concatenate(concat_arr, ''))
    // // Add concat field to feature dict
    feat['attributes']['concat_vals'] = concat_str
    Push(
        out_dict['features'],
        feat
// Return populated dict
return FeatureSet(Text(out_dict))
I tested this against another layer, and it successfully returns a "concat_vals" field, which your chart would then be able to see.
- Josh Carlson
Kendall County GIS
jcarlson
    false
Push(
    fields,
var out_dict = {
    fields: fields,
    geometryType: '',
    features: []
for (var f in fs){
    var concat_arr = [
        f['COD_A'],
        f['COD_B'],
        f['COD_D'],
        f['COD_L'],
        f['COD_M'],
        f['COD_N'],
        f['COD_P'],
        f['COD_Q'],
        f['COD_R']
    Push(
        feat
- Josh Carlson
Kendall County GIS
MiltonSolano
Wonderful Josh,
it worked straight from the forum! Thank you for taking the time to help with this.
Milton
