How do i create this Indicator?
1465
11-25-2019 05:48 PM
JamieLambert
I was looking at this blog by David Nyenhuis‌ (https://www.esri.com/arcgis-blog/products/ops-dashboard/decision-support/visualizing-data-effectivel...) and was after more information on how to create an Indicator like the example below. Here is the Operations Dashboard: https://www.arcgis.com/apps/opsdashboard/index.html#/73f32a5e74e748599c38124ba4337fbe.
Is it just a case of how you configure the Bottom Text? I haven't seen any border setting for an Indicator... Thanks!
ChelseaRozek
MVP Regular Contributor
When dragging a widget, hold down the shift key, the docking icons will change to green and you can dock them more within each other like the dashboard you were looking at shows
ChelseaRozek
JamieLambert
Perfect! Thanks for that.
