hide the map in OD
4214
6
07-04-2018 01:37 AM
eyadghatasheh
Hi
How Can I hide the map in an operations dashboard?. I just added the feature class to be able to publish a geodatabase table and want to show non spatial statistics on the dashboard only.
DerekLaw
Esri Esteemed Contributor
Hi Eyad,
You can create a new Operations Dashboard app without having a map element. Just create a new dashboard with no map element. If you access Ops Dashboard from the Map Viewer, a map element is added by default, but you can simply delete it, then add a different element, then browse to a data source directly.
Hope this helps,
eyadghatasheh
Hi Derek
I tried that;but the issue is once I delete the map element, it deletes all elements and I have to recreate and design them all from scratch.
DerekLaw
Hi Eyad,
> ... the issue is once I delete the map element, it deletes all elements
I do not observe this behavior. For all of your elements, when you specify the data source - you need to browse directly to it's location - separate from referencing the data layer(s) in the map.
Hope this helps,
VHolubec
Dear Derek Law
I want to to bring back this issue. I need to display EditorDate field in a list form Hosted Feature table. In the non-map Dashboard. The problem is that the date is in US format and the date format can be changed just in pop-up settings in map.
So If I the map is missing in the Dashboard, I am not able to format the date to one common in Europe - Day/Month/Year. For European users, the US format month/day/year can be very confusing.
So I would like to ask, if there is a option how to hide a map element in Operations Dashboard?
Thank you,
Vladimir
Vladimir
DerekLaw
Hi Vladimir,
> ... if there is a option how to hide a map element in Operations Dashboard?
If a Map element is present in the dashboard, then no - there is no way to hide it in the display. Sorry. Please post an enhancement on the ArcGIS Ideas site for ArcGIS Dashboards.
Hope this helps,
DiegoLlamasOlivares
Hello Derek,
I have an issue with OD, I have a table that I need to refresh. I am able to refresh my single table (hosted) using a web map and I use update interval in order to refresh the changes from the table that is updated. If i use the item in the OD, i am not able to refresh data without close chrome tab or refresh it manually.
Is there a way to do that without map option in OD?
Regard,s
DLL
