Having problems with details not showing up with arcade content
2248
08-16-2023 09:45 AM
ChipMorgan65
All,
   I'm having problems displaying the portion of details widgets that contain Arcade content.
   I have simplified the Arcade content down to "Hello, world", and it's still not showing up. As a test, I'm displaying an image and field list in addition to the Arcade content and both of those show up correctly. My Arcade content shows up correctly in the table pop-up in the underlying map.
   I saw that there was a Dashboard patch made a couple months ago. Any thoughts?
Solved: Detail elements not working when popups were creat... - Esri Community
   Chip
ChipMorgan65
@AlixVezina Thanks for replying.
   I actually figured it out after stumbling around for a while (and forgot to come back here and explain my error).
   I was not properly typing the returned data. I had completely replaced the default contents of the Arcade code window and was doing a "raw" return of a variable called html, as in:
return html
    Once I changed the return to the following, it worked great.
return {
  type : 'text',
  text : html        //this property supports html tags
   Chip
AlixVezina
@ChipMorgan65 Is your arcade popup content configured for a Table layer (rather than a feature layer)?
marksm_macomb
@AlixVezina I am currently running into this problem, and yes I am configuring the pop up for a related table. I got this to work in Enterprise and was trying to recreate the dashboard in AGO, but it is not working in AGO. My arcade popup element is returning a text element. The text element shows in the Map Viewer popup, but not in the dashboard details widget.
AlixVezina
Hi @marksm_macomb
I believe this may be a known bug that the team is working to resolve. BUG-000162393
marksm_macomb
Thank you!
ChipMorgan65
return html
return {
  type : 'text',
   Chip
