Group Value filtering issue (possibly language/font issue)
1314
12-26-2019 10:24 PM
JinhoKang3
I'm trying to create a category selector in header panel to filter out the area based on province name in Korean language.
I made it sure that the correct feature layer gets filtered under the actions tab, and the interface displays everything correctly.
However, when I select one of the province, the map displays nothing. It filters out everything including the selected group value.
So I tried to convert the Korean-font-value field to english to see if it's a language issue, and it seems like it's an language/font issue.
I configured the group value to use the english-converted field, and tested out the filter, and it displayed the selected value correctly. (This case, City of Seoul)
Is this a known bug/issue? I'd be happy to share the data.
DerekLaw
Esri Esteemed Contributor
Hi Jinho,
> ... when I select one of the province, the map displays nothing. It filters out everything including the selected group value. ... So I tried to convert the Korean-font-value field to english to see if it's a language issue, and it seems like it's an language/font issue.
Can you please contact esri Tech Support and open an incident? They are the best folks to help you investigate if this might be a bug. You can share your data with them and provide detailed steps to reproduce the issue.
Hope this helps,
JinhoKang3
Hi Derek.
Esri Korea is assisting with this issue. Esri Case #02464614
Apparently, the "Use Standardized Queries" configuration is set to 'False' in ArcGIS Online's 'services1' server.
HQ's engineer is looking into it at the moment.
Thanks!
