Group By Expression
2067
6
08-14-2023 09:46 AM
Cheetah24
Hi
I'm trying to use a table and by species display totals for Alive, Injured and Dead animals. I am trying to use an expression and return a featureset that displays the totals for each of the mentioned but can't get it right. The field i have as the Data populated as 'AOR', "DOR' and 'IOR'. How can i sum these by value and display them in the correct column? So for each species I need to know how many were alive, dead and injured for the entire dataset.
Thanks
KenBuja
MVP Esteemed Contributor
I use the GroupBy expression like this to get the counts of each attribute in a field (Habitat).
var totalHabitat = GroupBy(fs, 'HABITAT', { name: 'HabTypes', expression: '1', statistic: 'COUNT' });
This gives me this table by setting the Category field to "Habitat" and getting the sum of the "HabTypes" field.
Cheetah24
Thanks for the response.
I had tried something similar but it just counts the number of rows. It doesn't seem to care what value is in my "Alive" field.
KenBuja
How is your data formatted? Do you have individual fields for each category showing how many animals are in that category? Your initial description sounded like there was one field showing if it's alive, injured, or dead.
Cheetah24
So it would be something like this:
BullfrogAOR
MinkDOR
BullfrogDOR
CrowDOR
And what I would like to see in a table is
SpeciesAliveDeadInjured
Bullfrog110
Mink010
Crow010
Cheetah24
Finally got it working. thanks for your help
KenBuja
Great! What was your solution?
