Future Layers not accessible
2932
11-29-2024 10:22 AM
DrJumaKhudonazarov
Can someone advise  I  want to create a dashboard using future layers from the Survey123 URL  but getting the message that the layers are not accessible. What to do?
ChristopherCounsell
MVP Frequent Contributor
Can you try:
  • Go to the Hosted Feature Layer
  • Click 'create view layer' to create a layer pointing at your survey data, but where you can control access.
  • Add the view layer to your map and share it with the same groups/public as the map and dashboard.
  • Try configuring the dashboard now and see if they layer is accessible.
The layer not accessible message is generally something you might see on Feature Collection:
https://support.esri.com/en-us/knowledge-base/problem-unable-to-access-feature-layers-in-arcgis-dash...
I wonder if you are using one of the default survey layers where querying is disabled. Using the steps above will give access and secure your data.
RickeyFight
@DrJumaKhudonazarov
Is the survey published yet? Are you using AGOL or enterprise? Did you create the survey on survey123 online or connect?
DrJumaKhudonazarov
Thanks. Yes published, used connect , using AGC GIS online  organisation
DrJumaKhudonazarov
i am getting  above message
ChristopherCounsell
Can you try:
DrJumaKhudonazarov
Thanks this was very useful advice and great support
