Format date in a ArcGIS dashboard indicator to a more concise format
2141
07-19-2022 08:14 AM
GeorgeJones9282
Anyway to format the above date in the ArcGIS dashboard indicator to a more concise format(mm/dd/yyyy) ?
For instance is there a JavaScript function for it?
Kind regards.
KenBuja
MVP Esteemed Contributor
The easiest is using the Text function.
Text(Now(), 'MM/DD/YYYY')
jcarlson
Where's your "Date Updated" text coming from? Is this an attribute? Is it displaying in a popup?
If this happens to be a attribute, you can go into your layer's visualization settings, or else go into the map your dashboard is built off of (if applicable), and edit your attribute settings there. These settings should carry forward into your Dashboard.
- Josh Carlson
Kendall County GIS
ZachBodenner
MVP Regular Contributor
What can you do if your dashboard isn't using a map, but instead just working off a published map service?
Happy mapping,
- Zach
jcarlson
It will use the default formatting defined in the service. You can use a Data Expression if you need more control over it.
- Josh Carlson
Kendall County GIS
ZachBodenner
Thanks John, can you provide a link to documentation on that? As an example of what I working with, I have this field in a table in Pro, date field, just showing dd/mm/yyyy:
But then when I publish it to the web service used in a dashboard, the dashboard automatically adds the time stamp, with no way to configure the appearance within the dashboard:
Happy mapping,
- Zach
