Filter Results in the Map
1511
08-30-2018 09:29 AM
AhmadSALEH1
Hello,
Is there anyway t add a filter tool to the map in the dashboard same as the WAB? I see that I can add a search button but not filter!
Thank you,
Ahmad
DerekLaw
Esri Esteemed Contributor
Hi Ahmed,
Have you looked at the selectors functionality in Operations Dashboard? These actually offer quite a bit of filtering capability, Selectors—Operations Dashboard for ArcGIS | ArcGIS
Other options to "filter data" in Operations Dashboard are:
Hope this helps,
DerekLaw
Hi Ahmed,
Hope this helps,
AhmadSALEH1
Thank you Derek, selectors did the job perfectly!
